Matthew2r35's avatar
Jul 31, 2020
Can not log into router
Since the new edge upgrade I can not Log into router.
    • Matthew2r35's avatar
      Matthew2r35
      Tutor
      No I tried Chrome and edge it will not let me in. I set the router to factory setting and it still wont let me in.
      • FURRYe38's avatar
        Even with a wired connection? Using 192.168.0.1 or 192.168.100.1?
        Try this, disconnect the coax cable from the modem. Press the reset button for 15 seconds then release. Have a wired PC connected to the back of the modem on a LAN port. Try accessing the modems web page at 192.168.100.1 or 192.168.0.1...
