Orbi WiFi 7 RBE973
Reply
Cax30 port forwarding settings disappear
Frank007p
I add a custom port forwarding in my cax30 and apply. It looks like it takes but when I toggle back and forth in the menus, the custom port I just added disappear. I even tried the built in port settings and the also do not take. I have the latest firmware. Any insight would be helpful.
Message 1 of 3
Accepted Solutions
Frank007p
Re: Cax30 port forwarding settings disappear
Problem solved with help from Netgear Agent. She advised that I do a reset on the router/modem and it worked. I'm able to do port forwarding.
Message 2 of 3
All Replies
Frank007p
Message 2 of 3
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1451 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
