Denverrose3's avatar
Denverrose3
Follower
Jun 10, 2023
Cm1200 won't connect with my NH app?
So i am trying to check for a firmware update- cause its been a bit since it did one. We moved and got a new provider- app stopped working. Just had to RESET my admin passwords and such again. Did a reset, no change. Keeps saying my box can't be reached. I've tried it from the computer side as well to see if I could 'force' an update there was none to be had for it. I'm out of ideas on what's wrong. I've even uninstalled the app and cleared the cashe.
DOCSIS® 3.1 Cable Modem (CM1200) #Cm1200 Netgear(Cable modem) nighthawk set with smart wifi router. got it back in 2021.
