hlstatum's avatar
hlstatum
Follower
Aug 11, 2016
G54/N150 wireless router set up second owner
I was given this router which had been previously used. I am having issues setting it up because everytime I try to plug in the IP address it says that it is already designated to another owner. I don't know how to change that or set it up. I own a Macbook Pro retina 13'. The Macbook also does not have an ethernet cable connection it.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello hlstatum
    I would try to do a factory reset on the device by holding in the reset button on the back of the router for 10 seconds then you can setup the router how you would like.
    DarrenM
