Jie552's avatar
Jie552
Follower
Jul 17, 2023
Internet speeds drops every few minutes to ~1Mbs download /.08 Mbs upload using the (C7000v2)
Repost to the relevant forum.
Heyo,
I am using the C7000v2 router and for the past month the download/upload speeds has been very slow and inconsistent compared to before and would drop to near 0mbs every few minutes. If anyone has an solution it would be greatly appreciated. Here are my logs and stuff.
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel615000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels (Partial Service)
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25636615000000 Hz-8.4 dBmV41.6 dB26731408
2Not LockedUnknown21525000000 Hz0.0 dBmV0.0 dB00
3Not LockedUnknown22531000000 Hz0.0 dBmV0.0 dB00
4Not LockedUnknown23537000000 Hz0.0 dBmV0.0 dB00
5Not LockedUnknown24543000000 Hz0.0 dBmV0.0 dB00
6Not LockedUnknown25549000000 Hz0.0 dBmV0.0 dB00
7LockedQAM25626555000000 Hz-11.1 dBmV31.9 dB125608571305057
8LockedQAM25627561000000 Hz-9.2 dBmV29.2 dB4037951114562
9LockedQAM25628567000000 Hz-9.7 dBmV32.3 dB5267120629234
10LockedQAM25629573000000 Hz-11.9 dBmV31.5 dB765163324717
11LockedQAM25630579000000 Hz-12 dBmV31.3 dB135706172432024
12LockedQAM25631585000000 Hz-10.2 dBmV35.2 dB39950310942
13LockedQAM25632591000000 Hz-8.5 dBmV31.6 dB2633042223220
14Not LockedUnknown33597000000 Hz0.0 dBmV0.0 dB00
15Not LockedUnknown34603000000 Hz0.0 dBmV0.0 dB00
16LockedQAM25635609000000 Hz-9.5 dBmV36.3 dB253225808
17LockedQAM25637621000000 Hz-8.6 dBmV30.4 dB670616427
18LockedQAM25638627000000 Hz-10.6 dBmV28.5 dB1953468577
19LockedQAM25639633000000 Hz-11 dBmV34.7 dB571415786
20LockedQAM25640639000000 Hz-10.9 dBmV38.6 dB246811263
21Not LockedUnknown41645000000 Hz0.0 dBmV0.0 dB00
22Not LockedUnknown42651000000 Hz0.0 dBmV0.0 dB00
23LockedQAM25643657000000 Hz-11.2 dBmV39.8 dB00
24LockedQAM25644663000000 Hz-11.3 dBmV39.3 dB00
Upstream Bonded Channels (Partial Service)
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA25120 Ksym/sec22800000 Hz54 dBmV
2LockedATDMA15120 Ksym/sec16400000 Hz53.9 dBmV
3Not LockedUnknown30 Ksym/sec29200000 Hz0.0 dBmV
4Not LockedUnknown40 Ksym/sec35600000 Hz0.0 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
TimePriorityDescription
2023-7-16, 22:49:18Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:49:04Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:49:04Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:47:41Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:37:25Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:36:13Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:25:48Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:24:42Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:14:36Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:14:26Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:14:25Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:13:11Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:02:57Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:02:51Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:02:45Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 22:01:40Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:51:16Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:50:10Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:40:00Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:39:56Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:39:44Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:38:37Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:28:15Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:27:07Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:17:14Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:16:50Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:16:49Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:16:43Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:15:37Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:05:22Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:05:14Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:05:12Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 21:04:07Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 20:54:03Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 20:53:59Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 20:53:55Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 20:53:48Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 20:53:45Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 20:53:44Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
2023-7-16, 20:53:44Warning (5)MDD message timeout;CM-MAC=14:59:c0:0a:70:c8;CMTS-MAC=00:90:f0:7e:01:00;CM-QOS=1.1;CM-VER=3.0;
1 Reply
