× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
NETGEAR C3700 allowing a 'Denial of Service' attack?
xnav
Star
Often early in the morning I experience hangs while using Safari on my Macs and iPads.  The hang doesn't last more than 5 minutes,  but I've discovered that during that time the router admin 'Attached Devices' page  shows a suspicious IP address (81.0.229.0) assigned to one of my iPad devices.
This IP also shows up in the 'Logs' page associated with a DoS attack.
A 'whois' shows the IP belonging to JanigaLabs-CZ.
I have screen prints if anyone thinks they can help.
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 6
Accepted Solutions
xnav
Star
Re: NETGEAR C3700 allowing a 'Denial of Service' attack?
I solved the problem by replacing the Netgear modem/router with a Motorola modem/router.
Message 4 of 6
All Replies
xnav
Star
Message 2 of 6
xnav
Star
Also see this.
Message 3 of 6
xnav
Star
Message 4 of 6
TheEther
Guru
This likely worked because you got a new IP address, not because the Netgear had a problem.
Message 5 of 6
xnav
Star
No, Netgear's own logs and displays show that there is a bug  in their code that causes the problem.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 13361 views
  • 5 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
