Orbi WiFi 7 RBE973
NOTICE: My Nighthawk CAX30 Cable Modem Router is not connecting to the Internet; what do I do
ChristineT
Admin
Hello CAX30 Community,
We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that might have resulted in an interruption to your Internet service. Please visit NETGEAR.com/FixCAX30 for detailed instructions on how to restore Internet connectivity.
We are continuing to investigate this issue, your feedback is appreciated.
Thank you,
NETGEAR Team
Message 1 of 4
Guru
Re: My Nighthawk CAX30 Cable Modem Router is not connecting to the Internet; what do I do
For those CAX30 users that can not access the modems web page, even after a factory reset, I got some information that TFTP method of loading FW on the modem can help resolve units that may not be accessible to it's web UI normally.
This process can be used to load the v1.4x FW on to the modem for the router portion and should hopefully bring back good operation of the modem:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Get the v1.4x FW file from here first:
https://kb.netgear.com/000065403
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Windows TFTP: https://pjo2.github.io/tftpd64/
Apple Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Can give this TFTP program a try as well:
https://github.com/jclehner/nmrpflash
If all this fails, users will need to make contact with NG support:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 4
ChristineT
Admin
The majority of our CAX30 customers have successfully restored connectivity using these two solutions. If you are still experiencing an issue after trying these steps, register your CAX30, then email NETGEAR support at cax30_support@netgear.com. Please include your CAX30 serial number in your email.
For help finding your serial number, see How do I find my NETGEAR home product’s serial number?.
Thank you,
Christine
Message 3 of 4
Guru
NOTICE:
For CAX30 users that do have working or semi working units and have WEB UI access to the modems web page, if your CAX30 unit has v2.x FW loaded, please downgrade the unit to v1.4x FW ASAP. V2.x FW has problems and was pulled from public download and use. Putting v1.4x back on the CAX30 will get the unit working correctly.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 7478 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
