Hybrid042785's avatar
Hybrid042785
Initiate
May 26, 2020
Netgear AC1900 Cable Modem Voice Router C7100v Lights flashing intermittent no wireless or lan conn
The router stopped working. I cannot connect via wireless or lan. The router will not even factory reset.
  • FURRYe38's avatar
    Contact NG support for help and information. Ask about an RMA if thats an option for you.
    Christian_R
    • Hybrid042785's avatar
      Hybrid042785
      Initiate
      Thanks for your suggestion. I contacted Netgear support last night and they will send me an rma.
      • FURRYe38's avatar
        Good to hear. Hope the new unit works well for you.
        Good Luck.
