Orbi WiFi 7 RBE973
Reply
Netgear C7000v2 bridge mode - 1 active ethernet port
nilsen9
Follower
(EDIT - appears that it is common and normal for only one port to be active. This can be closed).
I recently picked up an Eero mesh system and wanted to use my C7000v2 modem/router to just be a modem. As such, I put the gateway into “modem only” mode by turning the router portion off. However, I can only get one Ethernet port on the C7000v2 to work/be active. Since the Eero only has one extra port, I need the extra Ethernet ports on the modem. After turning off router mode does this really only have one active Ethernet port?
Message 1 of 2
Accepted Solutions
Kitsap
Master
Re: Netgear C7000v2 bridge mode - 1 active ethernet port
As you have found out, in modem only mode only one Ethernet port is active on your C7000v2.  This is normal operation for combination devices.
A four port unmanaged Ethernet switch is available for under $20 on Amazon.  Make sure you connect it downstream from your router and not between your C7000v2 and the router.
You can mark your post as resolved so others may benefit.
My setup: Xfinity -> Netgear CM2050V -> Netgear R9000 (Voxel V1.0.4.71.1HF)
Message 2 of 2
All Replies
Kitsap
Master
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 608 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
