trialcritic
Mar 01, 2025Guide
Netgear CM3000 No upstream channel locked - no light
I have an Xfinity Gigabit X2 plan.
I restarted my CM3000 modem and Orbi 970 router. I see that the upstream channel light is Off (implying No upstream channel is locked). I restarted the modem twice.
However, my internet is working fine. My modem says my downstream and upstream status is fine.
Here are my channels. My upstream shows multiple locked channels. Is there a problem?
Your values look pretty spot on. could be just a burned out led. If it bothers you, you can always return/exchange it. But if its working fine, you could just ignore it.
1 Reply
