andrewkarl903
Sep 15, 2020Tutor
Nighthawk C7000v2 dropping connection
Our internet connection is dropping 1-4 times a day every day for the past couple months. It typically comes back within 1-2 minutes, but this is very disruptive now that we are working from home due to the pandemic. Our ISP is Spectrum and they see no issues on their end. I checked the Nighthawk app and it says the firmware is outdated. However, when I go to routerlogin.net it tells me the firmware version is V1.02.09, which matches what Netgear says is the latest firmware for this device for Spectrum. So it appears the firmware is up to date and, since this is a modem router, I cannot update the firmware myself anyway. I have performed multiple power cycles and modem reboots, to no avail. Any thoughts on how to get this fixed? Thanks.
spectrums first response is always "its not our line, its fine". Because if its not, then they have to send out a technician and pay them to fix the line.
Many times we see issues with the line.
Log into the c7000 and get a screen snip of the cable connections page and the modem logs. This helps check the line.
Also, is it all devices that have issues when it drops, only wired devices, only wireless devices?
