- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk r8000 slower ethernet speed than modem ethernet speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r8000 slower ethernet speed than modem ethernet speed
1. what modem are you using? model
2. what firmware is on your router?
3. what speedtest site are you using? when it selects servers to test off, some speedtest sites don't always choose the best. also make sure you're hardwired in for testing and don't use a gaming console for speedtesting.
4. when you setup the router, make sure not to enable qos, traffic monitoring, access control. If you did enable those, you can try disabling and rebooting but some have needed to factory reset to fully clear them out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not every's bridge mode functions properly. Something to try is to re-enable the Arris's router mode and put the netgear in AP (access point) mode.
another thing you can try is the R8000 recieved netgear armor on the version your on. not all devices responded well. You can try downgrading the firmware a version. if you do this, make sure to do it over a hardwired connection, factory reset afterwards, and manually re-install (not from backup).
also, try dslreports.com for speedtesting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
if you do, make sure the routing function is turned back on on the modem/router you're using.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Get the IP address off your primary router for the R8000. the primary router is controlling dhcp and will give it an IP address. Should be in an attached device list (or whatever the primary router uses).
did the speeds improve
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
