FHCASE's avatar
FHCASE
Follower
Mar 21, 2021
Setting up a static IP address CAX80
It does not seem possible to set up a static IP address on the CAX80 Nighthawk 8-Stream WiFi 6 Cable Modem Router.
When you enter information into the page where you need to define the IP addresses and select "apply" the information on that page, including the IP address of the modem is blanked out.
Firmwear version is 2.1.1.4 (current)
Did anyone else experience this (serious) problem?
Thank you
  • FURRYe38's avatar
    What Static IP address are you trying to set? WAN Static IP address?
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Orbi with Built-in Cable Modem - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
