Piper43078
Sep 27, 2022Aspirant
Splitting/ switching a Modem signal
Can a modem signal be ‘split’ and then sent to two different/ separate routers??
If so what netgear product can achieve this?
Are you talking the coax connection?
Or connecting the coax to the modem and then using a switch on the modem?
If its option 2, most ISP's don't support that for a consumer connection.
Some do allow you to buy modem's with more than 1 output that you can connect more than 1 router to.
So a little clarification helps on what you're trying to do and what equipment you have.
- Piper43078AspirantThanks… not splitting the coaxial, trying to split the signal coming out of the Optimum modem and then to two separate routers.
I think you answered it… only 1 IPS per modem/ account….
Thanks- FURRYe38Guru - Experienced User
Might ask the ISP if they support having more than 1 WAN IP address to one line. Some ISPs may support that.
