itskian's avatar
itskian
Follower
Jul 27, 2018
Which Router & Modem Should I Use?
Hello, I am currently paying for a 400 mbps connection from spectrum. When they set it up they gave me one of their standard modems (Arris TM1602) and their standard routers (Sagemcom RAC2V1S). I currently have a Netgear C7000-100NAS router modem not in use. Right now I get up to 475 mbps max and was wondering if I should switch the router and modem Spectrum gave me and replace it with my Netgear one. Wanted to hear what I should to to achieve the max mbps I can. Thanks.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You can always try and hook it up and see if the speed improves you will just have to contact the ISP or use a online tool to switch the modems.
    DarrenM
