RemyMM
Feb 04, 2022Tutor
horrible modem router and support
spent FOUR hours trying to connect. ISP says it is connected but Nighthawk won't connect to FOUR separate devices and TWO different browsers due to privacy issues. GARBAGE. india support is absolutely wortthless
You didn't give us much to go off.
1. what router do you have?
2. is there a seperate modem (based off your title)?
3. what firmware is on the router ?
4. what actual error are you getting? A screen snip of it can help
5. what method of setup are you using? setting it up with an app? Using the browser?
Details are key since we're not there to see whats going on.
- RemyMMTutor
This is under NIGHTHAWK... it is a netgear nighthawk modem. AX2700 DOCSIS 3.1 WiFi Cable Modem Router (CAX30)
- RemyMMTutor
I get this error with Edge, Chrome, on my desktop, android phone, tablet...
Your connection isn't private
Attackers might be trying to steal your information from www.costco.com (for example, passwords, messages, or credit cards).
NET::ERR_CERT_AUTHORITY_INVALIDYour connection isn't private
Attackers might be trying to steal your information from www.amazon.com (for example, passwords, messages, or credit cards).
Apart from the Internet, your Nighthawk does not connect to anything. It is the other way round. Things connect to wifi, or ethernet, on the router and then to the Internet.
So you need to look at these devices and find out why they can't connect.
Do other devices connect?
What devices don't connect?
What firmware is on the CAX30? Unlike most cable modem/routers, this one allows updates.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual Update the router firmware.
