dragdrag45's avatar
dragdrag45
is there modem/router combo from netgear and does netgear support bell fibe ips?
Hello, im wondering if netgear supports bell fibe because i have a router and modem combo from bell and its got terrible wifi speeds and i was wondering if you can get a modem and router combo that is compatible with bell fibe internet.
  • > [...] im wondering if netgear supports bell fibe [...]
       Which "bell fibe"?
    > [...] i have a router and modem combo from bell [...]
       I can't see it from here.  Perhaps you could reveal what it is.
    • dragdrag45's avatar
      dragdrag45
      its bell fibe 2000 i was wondering if i could just buy a netgear modem and router combo and hook it up instead of the bell modem router combo.
      • antinode's avatar
        antinode
        Guru
        > its bell fibe 2000 [...]
           This?:
              https://business.bell.ca/shop/small-business/internet/modems/hub-2000
           If you're using its voice phone capability, then I'd guess that you'd
        want to keep the Bell Home Hub 2000 for your ISP interface, and use
        another router or access point for extended/improved wireless-network
        capability.
        > [...] i was wondering if i could just buy a netgear modem and router
           I doubt that Netgear offers a DSL modem(+router) with the same
        capabilities, but you can look.
