wyatt1963's avatar
wyatt1963
slow speed with ethernet cable
All
I am not a technical person
Having said that
I hooked up the ethernet cable from the Netgear router to my 1 year old Vizio TV, Pretty straight forward hook up.
When I do a speed test I get between of only 15-16 Mbps
I am paying for 150 Mbps from Comcast and there are no help
I did read that changing the channel might help so I changed it to channel 4 ~ no difference made,
Should I do a reset?
Please ~ I need some BASIC direction.
  • michaelkenward's avatar
    michaelkenward
    What hardware are you using? Your footer says C6300 but your message is in the General WiFi Routers (Non-Nighthawk) section.
    Is it only the TV that is slow?
    I don't know what you read or where you read it, but Ethernet doesn't use "channels" in the same way that wifi does.
    • wyatt1963's avatar
      wyatt1963
      UPDATE:
      I am using the following
      WIFI CABLE MODEM ROUTER
      Netgear Model: C6300
      Firmware Version
      V3.01.12
       I have slow speed over wifi when I do a speed test on my phone like 40-60 Mbps
      when I test my tv I only get 14-16 Mbps with the ethernet cable
      I changed the router back to channel 1
      Thanks for all input
        wyatt1963
        Update:
        How do I update the firmware?
        Does the ISP have to do it on their end or is it something I can do from Netgear Genie?
        This may be my issue with slow speed with ethernet cable attached per netgear support before I was cutoff.
        Thanks for any and all feedback
