guggilamsandeep
Nov 19, 2016Aspirant
C3700-100NAS - not getting enough speed using wifi
Hi,
I am using below netgerar modem **bleep** wifi router. My ISP is Time Warner Cable.
C3700-100NAS
When I connect wired, I am getting 200+ Mbps speed, but when I try connecting wireless, I hardly get 40Mbps speed. It is a dual band router and even with 5G freequency, I get same speed. I tried resetting the modem to factory settings and stil no luck. Any inputs on how to fix this issue
Wifi will always be slower than wired. You will never get the advertised speeds. Think of them as marketing guff.
Is it the measured speed that worries you or the fact that you can't do things because it is too slow?
If the former, it isn't worth getting worked up about.
If the latter, then you might want to check the device you are connecting with. Maybe it has updated drivers and things that you can apply.
You should also check that there aren't any steel doors between you and the router and that the router is in a position where it can broadcast a decent signal.
Not sure what an C3700-100NAS is. C3700 yes, but C3700-100NAS? Or is it the JNDR3000 that is causing you grief?
- guggilamsandeepAspirant
Thanks for the inputs. My case is latter and I don't have any steel doors in between. I get the less speed even if I sit infront of router. This is really frustrating.
They advertised that router is capable enough to get 300+ Mbps speed and I getting only 10% of it.
C3700-100NAS & C3700 are the same.
Below the router that is causing this.
Any other inputs on how to fix it? If no, can you suggest me the best affordable router that can help me to get the maximum speed like I was receiving from wired connection?
Did you investigate this bit in my message?
... then you might want to check the device you are connecting with. Maybe it has updated drivers and things that you can apply.
Before looking for another router, I'd look at other possible causes for this slowness.
I suggest this partly because you say you get the same speeds regardless of the wifi band you use.
If this wifi device gets superfast speeds somewhere else, then certainly investigate the router. If not, look at the device itself.
If you have a lot of neighbours using the same frequencies, then your wifi devices may be struggling to deal with the interference
As the manual puts it:
If many wireless networks at your location use the same channel as your wireless network, you might experience interference. You can change the channel to avoid the interference.
Have you tried using different wifi channels? ( See page 79-> in the manual.)
