Dlines24's avatar
Dlines24
Follower
Jun 16, 2016
C6300 cable modem router combo connection to switch
I am wanting to connect a switch for Ethernet that was pre wired through my new home and hook it to my c6300 cable
Modem router. Do I just connect one line to my modem then to the switch to make it active?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Dlines24
    Yea you should just have to connect a ethernet between the 2 devices and the switch should just work.
    DarrenM
