- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CG3000D Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
CG3000D Firmware
I just purchased a CG3000D Cable Gateway/Wireless router from Amazon. Supposedly new, put possibly not. I can't change the admin password beyond the default. It accepts the change, but doesn't actually change the settings. They stay the default. Also there is no place the change the SSID. It's listed in the right side help menu under Setup...Wireless Settings, but there is no actual field there. I've tried it on Chrome, FF and IE. Same result.
I know the firmware is old, 5.5.1, and cannot find any newer versions beyond the open source (http://kb.netgear.com/app/answers/detail/a_id/2649/kw/CG3100). Is this ok to install, and if so, how do I go about doing it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CG3000D Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't comment much because unit are commonly handle by the ISP as it may able to buy on retail base
http://www.netgear.com/service-provider/products/routers-and-gateways/cable-gateways/default.aspx
anything that fist in model shows in URL are ISP branded devices that netgear do offered any firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have the same problem and TW went into the http://192.168.0.1/ menu using their login credentials and they found NO WAY to update the firmware. they said there were no option for it on the screen & same for me (no option). so how is the service provider supposed to update if there is no update firmware option on the menu???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Romeocharlie
I have looked into the CG3000D this modem was orginaly sold to charter and wasnt a retail modem so we have no firmware support for this modem it would be handled threw the ISP here is a article talking about this. Sorry this dosnt help upgrade the firmware.
http://kb.netgear.com/app/answers/detail/a_id/24324/~/no-netgear-support-for-the-cg3000d
DarrenM
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
