Madlad90046's avatar
Madlad90046
CM1000 Spectrum ISP dropping every 5-30 minutes
Hooked up new Modem using the same connection I used for the spectrum modem no changes and everything worked fine for years except with 2 people working from home I wanted the multi channel upload.  The modem drops every 5-15 minutes is down for 10 sec up to a minute.  I'm running RG6. I really appriciate the help.
Hardware Version2.02
Firmware VersionV3.01.06
CM certificateInstalled
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel705000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv4 only
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM25631705000000 Hz1.1 dBmV40.2 dB53840152117144
2LockedQAM2561693000000 Hz1.6 dBmV40.4 dB5272569900
3LockedQAM2562525000000 Hz6.1 dBmV42.3 dB5272988900
4LockedQAM2563531000000 Hz5.7 dBmV42.2 dB5273354000
5LockedQAM2564537000000 Hz5.4 dBmV42.0 dB5273724400
6LockedQAM2565543000000 Hz5.4 dBmV41.9 dB5274115000
7LockedQAM2566549000000 Hz4.8 dBmV42.1 dB5274468200
8LockedQAM2567555000000 Hz4.4 dBmV41.8 dB5274793600
9LockedQAM2568561000000 Hz4.0 dBmV41.3 dB5275164600
10LockedQAM2569567000000 Hz4.3 dBmV41.4 dB5275581600
11LockedQAM25610573000000 Hz4.8 dBmV41.0 dB5275946300
12LockedQAM25611579000000 Hz4.5 dBmV41.7 dB5276251700
13LockedQAM25612585000000 Hz4.1 dBmV41.7 dB5276648200
14LockedQAM25613591000000 Hz4.2 dBmV41.6 dB5277026600
15LockedQAM25614597000000 Hz4.1 dBmV41.5 dB5277360600
16LockedQAM25615603000000 Hz4.2 dBmV41.4 dB5277725700
17LockedQAM25616609000000 Hz3.6 dBmV41.3 dB5278120500
18LockedQAM25617615000000 Hz3.5 dBmV41.4 dB5278476800
19LockedQAM25618621000000 Hz3.4 dBmV41.2 dB5278854500
20LockedQAM25619627000000 Hz2.7 dBmV41.0 dB5279236000
21LockedQAM25620633000000 Hz2.6 dBmV41.2 dB5279617500
22LockedQAM25621639000000 Hz1.9 dBmV40.9 dB5279987600
23LockedQAM25622645000000 Hz2.2 dBmV41.0 dB5280328100
24LockedQAM25623651000000 Hz1.6 dBmV40.8 dB5280717300
25LockedQAM25624657000000 Hz1.3 dBmV40.7 dB5281131700
26LockedQAM25625663000000 Hz1.1 dBmV40.4 dB5281464900
27LockedQAM25626669000000 Hz1.1 dBmV40.3 dB5281836800
28LockedQAM25627675000000 Hz1.4 dBmV38.7 dB5282217800
29LockedQAM25628681000000 Hz1.2 dBmV40.4 dB5282375400
30LockedQAM25629687000000 Hz1.6 dBmV40.5 dB5282507800
31LockedQAM25630699000000 Hz1.5 dBmV40.5 dB5282618200
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
1Not LockedUnknown00 Hz0.0 dBmV
2LockedATDMA224200000 Hz41.8 dBmV
3LockedATDMA330600000 Hz42.5 dBmV
4LockedATDMA437000000 Hz41.3 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 2, 25533380000000 Hz8.4 dBmV40.8 dB1108 ~ 29871379945851189784780
2Not Locked0, 25500 Hz4.1 dBmV0.0 dB0 ~ 4095000
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
1Locked3, 4, 12, 1311800000 Hz40.0 dBmV
2Not Locked3, 4, 12, 1300 Hz0.0 dBmV
  • Here's my event log...
    TimePriorityDescription
    2020-09-22, 05:04:04Warning (5)RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    2020-09-22, 05:03:47Notice (6)US profile assignment change. US Chan ID: 8; Previous Profile: 13 ; New Profile: 12 13 .;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    2020-09-22, 05:03:40Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 .;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    2020-09-22, 05:03:31Notice (6)TLV-11 - unrecognized OID;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    2020-09-22, 05:03:31Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    2020-09-22, 05:03:31Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    Time Not EstablishedWarning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv4
    Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    Time Not EstablishedCritical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    2020-09-22, 04:46:56Critical (3)No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    Time Not EstablishedCritical (3)Ranging Request Retries exhausted;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    Time Not EstablishedCritical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1;
    • plemans's avatar
      Do you have any splitters, attenuators, or amplifiers in line? if so, remove them.
      check all the connectors for loose/cheap/bad connections. Check the coax cable for kinks, damage, corrosion, etc.
      Preferrably, move the modem to right where the coax enters the home to prevent the wiring within the home being the issue.
      try it there.
      If it doesn't help, the isp needs to check the line based off your logs and cable connection info.
