- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1000v2 using with Google WiFi v2 on Comcast XFinity MOVED TO CORRECT FORUM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi I've moved this to the correct forum.
Hello! I am trying to connect my new CM1000v2 to Google Wifi but it's not working. When I am in connect mode, my phone, running Google Home, fails to recognize the Google Wifi point.
Google support says Comcast needs to re-provision to enable cloud routers. Comcast, across 3 separate calls, cannot seem to do that.
So, I've struck out with Google support (2 calls/chat sessions) and Comcast support (3 calls/chat sessions).
Anyone have a similar issue that was resolved?
Thanks and help 🙂
Eugene
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1000v2 using with Google WiFi v2 on Comcast XFinity MOVED TO CORRECT FORUM
Was the new CM1000v2 configured and registered with your cable ISP as lined out in the Nighthawk Ultra-High Speed Cable Modem Model CM1000v2 Quick Start Guide ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I @schumaku yes, I've been on 2 calls, one chat, and an inperson visit this AM. The modem is definitely connected and delivering better than expected WIRED speeds to my big honking home computer, but still cannot connect Google Wifi.
I had made two posts, this one in the wrong forum (newbie mistake) and then another in the correct forum, where there is additional stuff going on:
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem would be the Google router and wifi, not the modem. The modem would not prevent or cause wifi problems.
You'll need to refer to Googles support and information for help on there product.
Try a different wifi router...
