zbrozek
Jul 28, 2019Tutor
CM1200 does not assign IP address unless Ethernet cable is unplugged and plugged back in
I bought a CM1200 yesterday to replace a super-flaky SB8200. Unfortunately, the CM1200 only allows me to get an IP address right after cycling the Ethernet cable. This is a problem, as whenever I change settings my router reboots itself and I have to go cycling a cable to reestablish connectivity. There are no settings to speak of in the device configuration, so I can only assume that this is a firmware bug.
Swap the LAN cable between the modem and your connected device. CAT 6 is recommended.
What device do you have connected to the modem? PC or External router? Mfr and model#?
