Vojt's avatar
Vojt
CM1200 speed issue with Xfinity Gigabit service
Hello,
I have gigabit service with Xfinity, and I did a speed test and pulled 950mbs, instead of renting the XB6 I purchased the CM1200, now my speeds are ~450MBps. I did not configurations on the CM1200
I have a funky setup, I have the 4 ethernet ports on the CM1200 taken up, one goes into another switch which then goes into my other devices. Another ethernet port is for another switch that has more devices. Would it be better to daisy chain and just use 1 ethernet port from the CM1200 into the switch as opposed to using them all on the modem?
Thank you in advance!
  • FURRYe38's avatar
    No, for the CM1200, only LAN port 1 is to be used with a single NAT router behind it.
    Lan ports 1 and 2 support Link aggregation which you need a LAG supporting router to beable to take advantage of this feature. R7960P or R8000P which support LAG.
    The other ports 3 and 4 are for ISP static IP assigned addresses mostly seen in business class environtments.
    So for basic home needs, if you don't have a LAG supporting router, disable LAG on the CM modem and connect your main host router to port #1 only and leave the others disconnected on the CM modem.
    • Vojt's avatar
      Vojt
      Hi,
      Thank you for your response! I have a switch attached to port 1 of the CM1200, and another switch is attached to that switch, but all other ports on the modem are empty and all lights are green.
      I have tried a direct connection to the computer and modem, didn't help. I am not running wireless, only wired.
      • FURRYe38's avatar
        You need to move the switches OFF the modem and connected them behind a router.
        I would reset the modem and setup from scratch with a NAT router connected at Port #1. Have a wired PC connected to the NAT router. Might need to reset the NAT router and setup from scratch.
        I have this same modem, tested it for NG. Works well with my R7960P router, both in single port #1 and LAG modes.
    • Sleepdoc502's avatar
      Sleepdoc502
      Thanks for your help.  I see that ethernet port aggregation is disabled for the CM1200 and I have disaconnected the other LAN devices I had connected.  I reset the ORBI and was able to connect it to the internet.  I now have problems with the sattelites connecting to the ORBI.  While I upgraded the the cable modem, my whole house connectivity is markedly worse.
