oneplace's avatar
oneplace
Follower
Mar 31, 2016
CM400 Modem ethernet light blink yellow
CM400 Modem ethernet light blink ambler only when the router is connected, with out the router it is the same as all the other lights
Does any one no why?
I have tried different routers and different modems and it is the same for all
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi oneplace
    Welcome to the community!
    Amber Ethernet light means that the device connected to it is running on 10/100Mbps only.
    The Ethernet port is capable of up to 1000Mbps.
    • Lins's avatar
      Lins
      so that light blinks like that because the wireless router it's connected to has a slow speed?   Is it a problem?  My wireless router is at least 10 years old (linksys wireless g wrt546)... It still works so I've held off on replacing it.   I bought the cm400 because I was tired of paying the cable company....
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello Lins
        No problem at all it should work like that with older equipment.
        DarrenM
