DukerOfHazzard
Feb 17, 2021Aspirant
CM500 signal keeps dropping
Hello everyone,
Like many other people before me, I am having issues with my CM500 cable modem. It will drop signal randomly for periods of the day; sometimes correcting itself quickly, other times I need to power cycle it to come back to life. Other times it's fine for 2-3 days without incident. When it does go down, the upstream LED blinks. We have no amplifiers or attenuators, but we do have one splitter that was replaced after we started having issues. Below is the chart most people ask for when examining these issues. I am unsure on how to bring up the modem logs, I can post them if anyone can tell me how to access them. Any help is greatly appreciated!
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
You're getting a lot of timeouts. Thats when the modem isn't connecting back to the cmts. Tends to be line issues.
You can check your side of the line again for kinks, damage, loose/old/bad/corroded connectors. If you can't find anything, the isp needs to check the line
here's how to get the logs.
How do I view or clear the event logs on my cable modem or modem router? | Answer | NETGEAR Support
also, get the screen snip of the cable connections when its having issues.
- DukerOfHazzardAspirant
Time Priority Description 1970-1-1, 00:01:47 Notice (6) Honoring MDD; IP provisioning mode = IPv6 1970-1-1, 00:00:28 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2021-2-16, 19:38:00 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 19:10:25 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 19:10:24 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 19:10:24 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 19:10:05 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 19:10:05 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 19:10:05 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 19:08:56 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2021-2-16, 18:41:37 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 18:41:37 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-16, 18:40:30 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-14, 11:59:17 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-14, 00:32:07 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-14, 00:32:06 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-14, 00:32:06 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 05:40:42 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 03:23:26 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; 2021-2-12, 03:22:55 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 03:18:54 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 03:18:53 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 03:18:53 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 03:18:14 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 03:18:11 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 03:18:11 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-12, 03:17:03 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-9, 14:31:20 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; 2021-2-9, 14:30:49 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-9, 12:58:19 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-9, 12:58:18 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-9, 12:58:18 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-9, 12:57:10 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-9, 12:00:32 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; 2021-2-9, 12:00:24 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-9, 11:59:33 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; 2021-2-9, 11:58:34 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; 2021-2-9, 11:58:06 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; - plemansGuru - Experienced User
