AustinJerry's avatar
AustinJerry
Can't run Remote Desktop
New to Netgear routers. Just replaced my linksys with a Netgear C3700. It seems like the ability for two devices on the network to see each other and communicate is being blocked. For example, I can't ping my laptop from my desktop anymore. And I used to be able to run Remote Desktop between two computers on the network, but I can no longer make a connection. Please help me to configure the router to re-enable computer-to-computer connections.
  • Retired_Member's avatar
    Retired_Member
    What OS are you using.
    Most require you to select Home, Work or Public, because people couldn't figure out how to setup a network so they dummied it down. Like the public schools these days.
  • Yes, you are correct. After a bit of digging, I see the wireless network was set up as Public by default. Changing it to Home Network has resolved the issues--ping works, and Remote Desktop works as well.
    I wish I would have been presented with the option during setup...
    Issue closed.
    Retired_Member
    AustinJerry,
    Not a netgear issues this time. LOL
    You can go in and click on the House Icon and merge or delete previously connected networks. You can also choose treat all future networks connections the same.
  • The house next to the word "home network"..
    I hate how MS did that, the option isn't that "Visible"... Once you know it's there your okay, but most tech people don't tend to randomly click pictures in hopes of changing settings ;P....
    Retired_Member
    or stop to ask directions LOL
