dseveride's avatar
dseveride
Compatibility question
Just picked up the R7900 Nighthawk x6 AC 3000 Tri_band wifi router and wondering if it is compatible with my current old ARRIS TM722G/CT modem. Or should I replace the old modem with a newer model?
  • There should be no compatibility issue.  If the cable modem can deliver the Internet speeds that you are paying for, then there is no need to upgrade it.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    you should ideally put the TM722G in BRIDGE MODE to avoid double NAT.
    • dseveride's avatar
      dseveride
      Not sure what NAT is but I whached a video on the steps to put in bridge mode. Since I purchased the new super fast router am I better off to purchase a newer updated cable modem that is more up to date. The modem I have was purchased in 2008 or 2009.
      Thanks for your help.
      • TheEther's avatar
        TheEther
        Guru
