ATVrider's avatar
Jan 16, 2017
Downstream LED flashing green
For the past few weeks I've been having issues with my wifi cable modem router. Both the 2.4 and 5 GHz will download at extremely low speeds. For the past few days the Downstream LED light has been flashing green. All other lights are solid green. I checked all of the connections and tried restarting the router several times with no luck. Any ideas on how to fix this issue?
  • This evening the light stopped blinking out of nowhere and the wifi is working normally. I have no clue why this corrected itself after a few weeks if not working correctly.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello ATVrider
    What is the model of cable modem that you have?
    DarrenM
  • It is the Netgear Nighthawk c7000 cable modem router. I purchased it in April 2016 but didn't start having been problems until recently. Today I reset it to factory setting and the light is still flashing.
  • Also, thank you for replying. Hopefully I can find a solution before just replacing it.
  • The issue cam back the next morning. The green downstream led light is now flashing again.
    • DarrenM's avatar
      DarrenM
      Hello ATVrider
      You may want to get your ISP to check out this issue as a blinking downstream light indicates that the modem can not lock onto a connection.
      DarrenM
