jreynolds1520's avatar
Feb 28, 2019
Flashing Amber lights
I installed a new R7000 today and all the jacks that I have a LAN connection are blinking amber.  Having said that I can confirm connectivity.  I have read up on this situation and read many different ideas and suggestions.  One of which saying blinking amber is fine al long as you have connectivity.  I have also read that it moght be configured for 10-100 instead of 1000.  So what's the verdict?  Normally amber means trouble however what's throwing me off is I have connectivity.  What should I do?  Thank you in advance for your time.
1 Reply
  • > [...] all the jacks that I have a LAN connection are blinking amber.
       What's connected to "all the jacks"?
    > [...] I have read up on this situation and read many different ideas
    > and suggestions. [...]
       Where?  Did you get as far as the R7000 User Manual?  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "Top and Front Panels"
    and "Table 1. LED and button descriptions".  Further reading might not
    hurt, either.
    > [...] Normally amber means trouble [...]
       If only there were some kind of documentation for this gizmo
    which might explain such things.  But, wait!!!
    > [...] What should I do? [...]
       Look at the connected devices, and decide if you should be seeing
    faster link rates?
