jedi5
Sep 22, 2018Aspirant
Help: CM600 No Internet Connection??
Hi everyone.
Hope someone might be able to chime in with some suggestions and help me out.
Have Xfinity Internet and should be getting 250Mbit for speed.
I'm getting a good 85-93ish max.
Had an Xfinity tech come out and he couldn't figure out the problem.
Have the CM600 with firmware V1.01.16.
If I connect directly from modem to my Imac, I get no internet connection at all.
If I connect from modem to Airport Extreme to Imac, I get internet.
My patch cables are good, they aren't the problem.
I've tried quite a few different cables and they all work.
I've reset the modem quite a few times.
I've completely cycled down the modem for hours.
When I try to connect directly using ethernet cable from modem to imac, no internet.
When I connect directly using same ethernet from from modem to router to computer, I get internet.
Can someone help out and tell me if I have missed a step or there are some settings I should look at?
Thanks!
- vkdeltaNETGEAR Employee Retired
Hi,
Pls post your event log and Connection table.
thanks
- jedi5Aspirant
I hope I did this correctly.
This information is modem to router to computer.
power levels are ok.
for no internet on your iMAC -->
1. If you change from airport extreme to iMAC with an ethernet cable, Please make sure to reboot the modem
2. Also, I think your iMAC may not been configured with DHCP mode causing this issue. Please check this. If you think, it is good, then provide output of "ifconfig" command from terminal app on iMac
for speed issue> check the speed of direct connection
if still open, This is most likely wrong bootfile issue. Please call comcast and ask them to send correct 250 Mbps bootfile.
- jedi5Aspirant
1. Yes, I have rebooted, reset, cycled down the modem.
Nothing seems to work.
Only time modem works is when it is connected to router.
How do I check speed of direct connection?
2. How should the iMac be configuered with DHCP mode? I just checked only I don't know what I should be looking at.
Here is the output of the ifconfig:
Last login: Sat Sep 22 08:33:32 on console
rafis-iMac-4:~ hejo$ ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
OHC6: flags=0<> mtu 0
OHC4: flags=0<> mtu 0
EHC36: flags=0<> mtu 0
EHC38: flags=0<> mtu 0
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=27<RXCSUM,TXCSUM,VLAN_MTU,TSO4>
ether 00:26:bb:5e:34:1a
inet6 fe80::18ed:7ae1:acf1:aaca%en0 prefixlen 64 secured scopeid 0x8
inet 10.0.1.58 netmask 0xffffff00 broadcast 10.0.1.255
media: autoselect (100baseTX <full-duplex,flow-control>)
status: active
en1: flags=8823<UP,BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
ether 04:1e:64:ee:2b:8e
media: autoselect (<unknown type>)
status: inactive
en3: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
ether 7a:d7:5f:1f:dc:21
media: autoselect (none)
status: inactive
fw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 4078
lladdr 00:26:bb:ff:fe:5e:34:1a
media: autoselect <full-duplex>
status: inactive
p2p0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 2304
ether 06:1e:64:ee:2b:8e
media: autoselect
status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::150c:599:88a5:45e6%utun0 prefixlen 64 scopeid 0xd
the IP on your MAC BOOK seems wrong. It may be staticaly assinged to 10.0.0.x subnet.
see this to change the configuration to DHCP
https://support.apple.com/kb/PH25448?locale=en_US
