aaronedmiston's avatar
Oct 30, 2016
Help Updating Firmware to V2.01.14
I have a C6300 modem router combo on firmware V1.02.20, and recently found our that V2.01.14 is available. I have tried contacting Mediacom to push the update to my modem router as I had seen was necessary from multiple posts on the subject with other ISPs. Mediacom told me that they don't have anything to push since they only have firmware for the modems and routers they provide. They then told me to contact Netgear and have them push it through since they can access modem routers directly. I'm at a loss for what to do now since my router is beyond the 90-day complimentary support and I don't have $49 to spend on support to update my firmware. Any help with the issue would be greatly appreciated.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello aaronedmiston
    The Firmware is different on every ISP and Netgear can not upgrade the firmware on cable modems it is all pushed out by the ISP even if its a customer owned modem.
    DarrenM
