- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Internet Speed Dropping on AC1900
I currently have Cable Internet with over 100Mbs download speeds. During the day I am often getting download speeds of 28-42Mbs, however in the evening (when I will be the only one using the internet), my speed often drops to 1-4Mbs. I still show upload speeds of 10-12Mbs but the download speed is awful. I will often unplug the Modem/Router and it will get slightly better (like 7Mbs). I have called my cable company to have them look at the issue and they have told me it is not signal coming to the house and that it must be the equipment.
Any ideas what the issue might be?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Internet Speed Dropping on AC1900
Whats the Mfr and model# of the ISP modem? IF this modem has a built in router, it needs to be put into transparent bridge mode. If it can't be, then use the modems DMZ for the IP address the NG router gets from the modem.
Disable any wifi radios and uPnP on the modem.
RBK50 v2.7.2.102
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for the reply. You are going to have to bear with me as this not my area of expertise (and clearly it is yours). I have the Netgear AC1900 that I am using as my modem and router so I do not have any equipment from the ISP. I hope that answers your question....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Well there is a modem or ONT some place since the router doesn't actually do any kind of modem work or ONT work.
What is your ISP service? Cable or Fiber?
Where does the Yellow internet port connect too on the router? Wall outlet?
Is the NG router getting a public IP address ##.##.###.### or a private IP address, 192 or 172 or 10 something on it's internet port?
Do you have any QOS enabled?
Speed testing on ethernet connections to check speeds when this happens?
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
AC1900 is not a Netgear model number, more a wifi speed indicator.
Is this a D7000 of some sort? That's the DSL modem/routers.
For cable it could be C6300, C6900, C7000, C7100, or something else.
The model number is on the device somewhere.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
https://www.netgear.com/home/products/networking/cable-modems-routers/C7000.aspx
It is a modem and router combo. I am not sure how to find my IP address using my iPad (the genie app had not been helpful to me).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I just realized that when I replied to another user who had questions for me I did not reply to you as well.
Here is the modem/router combo that I have :
NETGEAR - Nighthawk Dual-Band AC1900 Router with DOCSIS 3.0 Cable Modem - Black
My provider is Time Warner Cable (I guess now Spectrum)
I am not sure how to get to my IP address. I am not sure why I am experiencing such drops in my Wifi Speed when I am the only one on the network.
Thank you,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello Lmackedanz
Try to log into your router via your web browser by using 192.168.0.1 in your web browser should prompt you a login use admin/password to login then navigate to the event log in Advanced-Administration-Event log and post the results here.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello,
Here is what I saw.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
At the time I posted this I was getting download speeds of 14mps and uploads of 9.57mps.
Thanks,
Lee
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You may want to check out this KB on how to improve wireless performance.
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you. I will give that a try. I am in a subdivision and I can see a number of available wireless networks so it is possible i will want to change my channel.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello,
I was unable to move the router (and the location isn’t a problem during the day), I also noticed that my router automatically picks the best channel automatically.
I am am not sure what else to try.
Lee
