agent4043
Jul 21, 2016Aspirant
Ip address conflict
Hi,
How can I reconfigure the ReadySHARE (Internal Server) to a different IP address? It is conflicting with another device on my local network. It seems hard coded at 192.168.0.10 and I don't see a way to change it or disable the feature.
Thank you,
-eric
1 Reply
- agent4043Aspirant
I found a work-around. I lowered my DHCP range to cover .10 and created a reservation for my SAN (the conflicting IP). I did not need to convert my SAN to DHCP, the reservation was enough. ReadyShare was reassigned 192.168.0.107
Not that I find this an acceptible solution... there should be a way to assign this IP. Would be interested in hearing any ideas.
Thanks,
-eric
