Anthony_Heman's avatar
Jan 05, 2021
Mediacom owned Netgear CM1000 has recent Very Slow Upload
I've had this modem for since October 2017 and it  has done the job well up until about a month ago. Download speeds are all still great (130 megs, paying for 100), but upload is miserable... mostly at night (0.1 megs). During the day it might get as high as 5. The weather has been cold, and people are home a lot more, I'm not sure if any of that could matter. Technical support was convinced it was the modem, but they didn't ask me for any information from it like power, which I see mentioned a lot here. Well I decided to order a new CM2000, not that I need the speeds that offers, partially because I wanted to be able to test it myself, but I was curious if there was anything discernable from the status page that someone might consider an obvious problem.
For testing I've isolated the modem to directly connect to my desktop PC and get the same speed results. I've also tried going off the wifi in a separate test (since that goes through a different cable just to rule out eithernet... I guess) and got the same results.
I think I'm using the best coax I have access to in my apartment, but I'm not positive. It's the only one I see that makes sense as where "it comes into the apartment." Other rooms are wired up however, but nothing about that should have changed (and I don't actually use the coax for anything but this cable modem).
Hardware Version 2.02
Firmware Version V3.01.04
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM2561111000000 Hz7.4 dBmV42.4 dB3123086400
2LockedQAM2562117000000 Hz7.1 dBmV42.6 dB3125307000
3LockedQAM2563123000000 Hz6.8 dBmV42.5 dB3126157800
4LockedQAM2564129000000 Hz7.6 dBmV42.8 dB3127078900
5LockedQAM2565147000000 Hz7.9 dBmV43.1 dB3127974900
6LockedQAM2566153000000 Hz8.1 dBmV43.3 dB3128914900
7LockedQAM2567159000000 Hz8.2 dBmV43.3 dB3129836400
8LockedQAM2568165000000 Hz8.3 dBmV43.3 dB3130791600
9LockedQAM2569171000000 Hz8.4 dBmV43.2 dB3132076400
10LockedQAM25610177000000 Hz8.3 dBmV43.0 dB3132985500
11LockedQAM25611183000000 Hz8.5 dBmV43.3 dB3133913700
12LockedQAM25612189000000 Hz8.2 dBmV43.2 dB3134853300
13LockedQAM25613195000000 Hz8.2 dBmV43.0 dB3135789800
14LockedQAM25614201000000 Hz8.4 dBmV43.2 dB3136763900
15LockedQAM25615207000000 Hz8.5 dBmV43.2 dB3137404300
16LockedQAM25616213000000 Hz8.5 dBmV40.2 dB3137894810
17Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
18Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
19Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
20Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
21Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
22Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
23Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
24Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
25Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
26Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
27Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
28Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
29Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
30Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
31Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
Upstream Bonded Channels
1LockedATDMA136500000 Hz26.0 dBmV
2LockedATDMA229750000 Hz26.0 dBmV
3LockedATDMA322750000 Hz24.8 dBmV
Downstream OFDM Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 2200309000000 Hz8.7 dBmV40.3 dB148 ~ 39471224794429102300
2Not Locked000 Hz8.4 dBmV0.0 dB0 ~ 4095000
Upstream OFDMA Channels
1Not LockedUnknown00 Hz0 dBmV
2Not LockedUnknown00 Hz0 dBmV
  • Not all of your downstream channels are locked and your upstream power is really low. You should be 35+ on the upstream. you're at 26.
    Your logs would tell us more but it indicates a line issue at this point.
    If your isp is saying "its not our lines, its the 3rd party modem" and won't fix it, I've had to actually rent a modem before to prove it was a line issue. Once its fixed, I simply returned the modem and put mine back in.
  • plemans's avatar
    • Anthony_Heman's avatar
      Anthony_Heman
      Initiate
      Interestingly I was able to kinda take your words and the lines from my stats page and get them to send out a tech... it won't be for a week, but that's better than getting the new modem, trying it out, seeing that it doesn't solve the problem and then waiting another full week after that.
