tcq
Oct 12, 2017Aspirant
Modem CM500: many channels not locked; slow connection (1-2mbps)
See below. Is it normal for many channels not locked? The Internet starts fast, but over one hour or so drops to crawl speed (1mpbs or less). A reboot of the modem often fixes the problem, but it will gets slow again over time. Is this a cable problem or modem problem? Any advice is appreciated!
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels (Partial Service) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels (Partial Service) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
you have a serious noise issue either in home wiring or ISP's line. that is why most your downstream channels are NOT locked. and whatever is locked have lot of uncorrectable errors.
what modem did you have before CM500? did it have same problem? or you are moving into a new house/apartment?
- vkdeltaNETGEAR Employee Retired
please post the screenshots of connection page, event logs and who is your ISP?
did you try with device directly connected to the modem?
have you tried isolating your Router?
- tcqAspirant
ISP: comcast/xfinity.
- tcqAspirant
Event LogClear Log Refresh Time Priority Description 2017-10-11, 21:49:07 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:49:28 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:49:28 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:49:29 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:49:50 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:49:50 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:49:52 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:13 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:13 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:14 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:35 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:35 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:37 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:57 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:57 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:50:59 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:51:19 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:51:19 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:51:21 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:51:42 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:51:42 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:51:44 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:04 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:04 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:05 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:27 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:27 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:28 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:49 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:49 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:52:50 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:11 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:11 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:12 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:33 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:33 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:34 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:55 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:55 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0; 2017-10-11, 21:53:57 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=10:da:43:fc:c9:48;CMTS-MAC=00:01:5c:63:e0:7b;CM-QOS=1.1;CM-VER=3.0;
Help Center
Show/Hide Help Center
