Tillamookwaffle
Jul 02, 2019Follower
NETGEAR DGN2200V4 ROUTER SETUP - wifi speed issues
I've set up my DGN2200v4 as WAN only to use it as a router. ISP and LAN speed is 100 mbps. The modem is netgear nighthawk CM1100. WIFI is barely getting 5 mbps. I've changed the channel and lowered the MTU, but it has had no effect with on the speed.
also, when i use the NETGEAR ANALYTICS app on my phone, it reads at 50+ mbps while speed test sights read less than 5 mbps.
any way to increase the speed of the DGN2200v4?
Please post about this in the DSL modem forum for your model modem:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Also be ware of older modems and WiFi, this model only supports the following:
IEEE® 802.11 b/g 2.4 GHz with some n features
So WiFi speeds maybe slow.
Might be time to upgrade WiFi.
Good Luck.
- rahul6Aspirant
Thanks For Sharing This Informative Article ...
Searching For Best Earphones Under 1000 in 2019 then Click On This Link
https://phonespick.com/best-earphones-under-1000-in-2019/
