Reply
Nighthawk C7500 stopped broadcasting 2.4G
andreys
A few days ago I've noticed that some of my devices running on 2.4G Wifi got disconnected. I routerlogin.net to my router and can't find 2.4G setup anymore. I did factyory reset, which didn't helped. Now, I can't even change SSID name, nor my passphrase. Web UI simply doesn't do anything and does not responding when I click "Apply". Also it prompts me for user name and password every time I click on any link within Routerlogin.net UI. The firmware version is V1.01.32. Is anyone else experienced this?
Model: C7500|Nighthawk X4-AC3200 WiFi Cable Modem Router
Message 1 of 4
Guru
Re: Nighthawk C7500 stopped broadcasting 2.4G
So disconnect the ISP Coax cable and the power adapter from the modem for 1 minute.
Reconnect the power adapter to the modem only.
Power ON the modem and let it come to ready.
Press the reset button for 10 seconds then release.
Connect 1 wired PC to the modem.
Walk thru the modems setup wizard.
After completing the wizard, check the Basic tab/Wireless settings page. Does 2.4Ghz appear here or seem accessible or indicate any problems?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 4
andreys
"Reconnect the power adapter to the modem only." - this unit is modem + router combo
Message 3 of 4
Guru
Yes. I know. The statement was in reference to only connecting the power to the modem only and don't connect the ISP coax line.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 202 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
