mcwheeler
May 30, 2018Follower
Possible to connect CM700 cable modem on a Mac without an ethernet cable?
Is it possible to set up the CM700 modem without an ethernet cable? Neither of my Mac computers have an ethernet cord. Help!
The CM700 User manual says no. (Visit http://netgear.com/support ,
put in your model number, and look for Documentation. Get the User
Manual.)
During the installation and activation, you must connect the cable
modem directly to a computer.
And, the CM700 is only a modem, not a modem+router, so it has no
wireless capability on its own, only that Ethernet port.
You need older Macs or more Ethernet adapters. Or, a friend/victim
who will provide you with an Ethernet-equipped computer (with any OS)
for a while.- i4abuyAspirant
What about connecting it do a router with an ethernet port? Could the modem be addressed through the router?
You could run the experiment. I haven't, so I can't guarantee
failure, but I wouldn't bet on it working. It all depends on the
details of what the modem expects from the connected device, and the
environment it provides. About all of which I know nothing.
