mjz
Oct 20, 2016Apprentice
Questions about connecting my ISP's Pace Gateway 5268AC
My uverse residential gateway (router) was replaced with a Pace 5268AC router. When I tried to connect my current Netgear GS748t-v4 switch, The pace router does not "see" it. Is there anything I can do? I prefer to wire the switch directly into the back of the router so I can access it.
I was able to connect the gs748t to an old Linksys switch which is then connected to the Pace router and it does work - I can see my devices, but now the GS748t is invisible. It's not listed anywhere on the router device table, I am unable to "discover" it.
I want to go directly from the GS748t directly into the ethernet port of the Pace 5268AC.
Any suggestions on how to get the Pace to see the switch?
- netwrksMaster
Is the Netgear GS748t-v4 switch in the same subnet as the Pace router?
- mjzApprentice
Yes ... in fact, I tried to plug it in directly to one of 4 ethernet ports on the back of the Router.
I have only one network domain - no subnets. All IP's are assigned by the DHCP server on the router.
- netwrksMaster
Whats the ip address of the switch? What's the DHCP pool on the router? Is the Ip address for the switch in the same subnet as the router?
EDIT: FYI, 192.168.0.1/24 is considered a subnet, not a domain.
