- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to reach 500Mbs using Netgear CM600 cable modem and R6400v2 router with WoW! internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I upgraded my internet service with WoW! three days ago from 100Mbs to 500Mbs. I have not been able to get over a download speed of 120Mbs and upload speed of 24Mbs. They are unsure why this is happening and so am I. I do not know where in my setting to make the router and modem receive the 500Mbs. Any help and knowledge is greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to reach 500Mbs using Netgear CM600 cable modem and R6400v2 router with WoW! internet
Test it first directly connected to the modem with a pc/laptop. its pointless to troubleshoot a router if the modem is the issues.
So what speeds do you get directly off the modem?
what speeds does wow rate the CM600 for their service? (its different for each isp)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did test directly from the modem on a laptop, it was 35Mbs download and 24Mbs upload, I also have tested from a desktop connected to a repeater that is plugged into the wall outlet, the last time I tested that it was 90Mbs download and 13Mbs upload. It has been as high as 130Mbs download and 24Mbs upload. The people from WoW that I have spoken to have all said that the modem should be able to handle 600Mbs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
do you have a screen snip of the modems cable connection page and its logs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Again, make sure to remove the router. You need to first get the modem up to speed.
And if the routers having issues as well (unknown) it can complicate things.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where would I find the modems cable connection page and its logs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Log into the modems web page and there should be a connection status button or tab to select on. (192.168.100.1) This page will have a channels, signals and more information regarding the modems and it's connections to the ISP service. You can copy and paste this information in the next post or output to pdf file or some text file and select the Choose File button on the next post to attach it to the post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Choose File button on the next post to attach it to the post. We have to wait for inline pictures to be approved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Downstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Current System Time: Tue Jul 27 16:03:50 2021 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you also have your logs?
You don't have a lot of errors but your power is a bit out of spec. The channels should be within 3.5dbmv of each other. You're a bit out of that.
if you have any splitters, amplifiers, or signal attenuators in line, remove them.
Check the link for kinks, loose/old/bad/cheap/corroded connections and remove them if you do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Time | Priority | Description |
2021-07-27, 21:22:41 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-07-27, 09:22:56 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-07-25, 14:08:04 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-07-25, 03:06:58 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-07-24, 10:47:01 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-07-24, 10:42:15 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-07-22, 03:35:11 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-07-21, 06:16:47 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-07-16, 19:22:40 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-06-09, 00:08:40 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-06-09, 00:07:23 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-06-09, 00:04:30 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-06-08, 11:29:12 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-06-05, 01:47:06 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-06-03, 01:17:30 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-05-30, 03:24:25 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-05-28, 11:40:18 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-05-25, 11:17:47 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-05-25, 11:06:33 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-05-19, 00:12:43 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-05-19, 00:08:48 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-05-19, 00:08:44 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-04-28, 04:34:28 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-04-26, 14:08:54 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-04-21, 14:13:37 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-03-15, 17:41:31 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.1;CM-VER=3.0; |
2021-03-11, 14:14:47 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.0;CM-VER=3.0; |
2021-03-11, 14:14:25 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
2021-03-11, 14:14:21 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.0;CM-VER=3.0; |
2021-03-11, 14:13:54 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
2021-03-11, 14:13:52 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
2021-03-11, 14:13:50 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
2021-03-11, 14:13:49 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=b0:7f:b9:6a:ae:d8;CMTS-MAC=00:01:5c:b7:7e:49;CM-QOS=1.0;CM-VER=3.0; |
Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lots of criticals...
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://highspeed.tips/docsis-events/
I am assuming thats not good. I was considering buying a new modem, what would be your recomendation?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try a new modem for sure and see if these are seen on the new modem. If they are then the ISP needs to review there service line and signals UP to the modem. If the problem is not seen on the new modem then the CM600 could be faulty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, I've had this modem for a few years, probably close to 4 or 5 years. So it would not suprise me if it was going out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try another CM modem. CM1000, 1100, 1200 or 2000. See what one of these reports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd also check the line carefully. Move the modem to right where the coax enters the home to prevent wiring in the home being the issue.
The docsresets are issued from the cmts usually. And t3 tends to indicate line issues.
not saying somethings not wrong with the modem but those errors tend to be line issues
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
