Bionicjuiceman's avatar
Dec 05, 2016
Using C3700 n600 as router to connect to dsl modem
So I moved to out to the "country" and only get Windstream 6mb DSL now. It came with a cheapo sagecom DSL modem/router. Router side is very weak on it. I only have the c3700 n600 modem/router as a possible solution. Would I benefit from bridging the sagecom modem and using the router side of the C3700 n600 as my wifi?
  • Hello Bionicjuiceman
    Sorry but the 3700 can not be used as a stand alone router it has no WAN port.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
  • Hey thx for confirming that. Thats whats I figured I was hoping that maybe 1 of those 2 lan ports was able to be a wan port. Thx
