birdieagle's avatar
birdieagle
Initiate
Feb 24, 2016
cg3000dv2 Devices drop internet intermittently
Information
Standard Specification CompliantDOCSIS 3.0
Hardware VersionR2.05A2
Software VersionV1.02.10T
 Using with XFinity cable internet.  Using this modem/wifi router for about a year.  Annoying problem is that every so often a device (an iphone, ipad, directv console, will drop the internet connection.  The connection to the router shows strong, just can't access the internet.  Sometimes power cycling the device fixes it, sometimes have to cycle the router.  Just got a wifi range extender to amplify the signal throughout the house and after 2 days, now devices connected to it drop internet intermittently, and the range extender requires a reboot.  More of a hassle than anything as it is usually no more than once or twice a day, but is there a solution?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Birdieagle
    Have you adjusted the wireless channel on the router it could be something interfering with the wifi. We have a android app called Netgear wifi analytics which can show you what the best channel to set your wifi network on.
    DarrenM
    • birdieagle's avatar
      birdieagle
      Initiate
      I did try that and used wifi analytics to find the best channel with the lowest interference.  Still was experiencing intermittent device drops from internet access.  Decided to bag the old modem/wifi router and go with different equipment.  Thanks for your interest.
    • kdobbs09's avatar
      kdobbs09
      Initiate
      I am having this issue as well. I have tried everything in the world I can think of. I tried 2 different cable outlets with a new cable, changed the channel multiple times, factory reset and gave it a new SSID and password and everything. When used with ethernet cable to my computer, it is smooth sailing, but the wireless does EXACTLY as OP described. Internet cuts out on all wireless connections, but the bars indicating connection to wireless router are full. I'm really not wanting to spend another $110 to be able to use my internet again. Anything else I can do? Thanks in advance!
      Karen
