cuasitos's avatar
cuasitos
open ports for amule
hi i am trying t open ports for amule  in mac but the config page sayme that The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote Management, Port Forwarding, Port Triggering and UPnP Port Mapping table.
whats wrong and i try to put differnt port for exzternal an the one i need in internal and dosent work too
  • > [...] i am trying t open ports for amule  in mac [...]
       Which ports?  How, exactly?  As usual, describing actual actions and
    their actual results can be more helpful than vague descriptions or
    interpretations.
       Is this "amule" the one described at http://www.amule.org/ ?  Which
    version?
    > [...] Please check your configurations of [...]
       What are all those data?
    • cuasitos's avatar
      cuasitos
      Ok the software is the one you put the address amule.org
      The port are tcp 4662 and udp 4672
      I went to advance config port fowarding add a service
      I put the name the tcp option external port the internal port numbers and apply and sayme another option are using that port
