Cuarzo's avatar
Cuarzo
Tutor
Jul 19, 2021
MR1100 Nighthawk Roaming Data Disabled
I have a new unlocked M1 nighthawk.  I purchased a data-only SIM card from Verizon.  I am getting the messages "Roaming Data Disabled" and "Mobile Broadband Disconnected" when I power on the device.
On the app first screen (see image) the words "Cellular Data Off" appear in the upper right corner
What settings do I need to change:
APN Verizon
Network Mode Auto
Band Region LTE ALL
Domestic Data (on)
International Roaming (off)
Advanced Info Tab:
Roaming Yes
IP Address 0.0.0.0
Radio Band LTE B12
  • addendum:
    the router will connect to a Verizon tower and flash blue when in range, but the moment the router is out of range of a Verizon tower (and in range of a U.S. Cellular LTE network for example) the light switches to amber and "Mobile Broadband Disconnected"
    • schumaku's avatar
      schumaku
      Cuarzo wrote:
      : the router will connect to a Verizon tower and flash blue when in range, but the moment the router is out of range of a Verizon tower (and in range of a U.S. Cellular LTE network for example) the light switches to amber and "Mobile Broadband Disconnected"
      Can you usually use for example a U.S. Cellular LTE network using a Verizon SIM?
      Usually "roaming" is international (see the screenshot provided above) when you are abroad.
      • Cuarzo's avatar
        Cuarzo
        Tutor
        Thanks so much for your reply.  On my iPhone for example I have a T-Mobile data plan but when roaming in rural areas with no T-Mobile coverage it automatically switches to U.S. Cellular.
