Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear M1100 keeps freezing and not broadcasting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-07
01:15 PM
2021-12-07
01:15 PM
I have a M1100 router that has worked perfectly up until the other day.. one morning I went to use it and it wasn’t showing up on the wifi list. I restarted it and no change. I reset it holding the back button but it did not help.. the router isn’t broadcasting a signal, I can’t connect to it via USB and then after about 10-20 minutes of being on, it stops responding.. If freezes and the only way to get it to respond to anything is to restart it.
Is there any way to do a reset/firmware update via USB?
I’ve also tried logging in through the browser but no luck there either.
Thanks
Pablo.
Thanks
Pablo.
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-07
01:29 PM
2021-12-07
01:29 PM
Re: Netgear M1100 keeps freezing and not broadcasting.
IF your referring to the MR1100, FW for this unit is kept here:
https://www.netgear.com/support/product/MR1100.aspx#download
As a full power OFF of the unit for 1 minute or more then plug back in been performed?
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-15
05:41 AM
2021-12-15
05:41 AM
How would I install that FW on the M1100? I can’t seem to connect to the device at all.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-15
04:37 PM
2021-12-15
04:37 PM
This seems a HW failure. Please do a factory reset and see whether the device can be rebooted.
Thanks
Message 4 of 4
Announcements
