stevenhar's avatar
Nov 05, 2019
Circle breaks some SSL sites
So we have Circle enabled any even on devices associated with an unfiltered profile some sites fail to load, typically timeout.
Examples of such sites:
Tried switched the device to unmanaged, still fails, only disabling Circle totally fixes the problem.
Originally tested on V2.5.0.30 but also the same on V2.5.0.38
    • FURRYe38's avatar
      I would make contact with a forum moderator and hopefully they can help you out.
      Blanca_O
      • stevenhar's avatar
        stevenhar
        Star
        Thanks have done that.
        Some more information is that wireshark shows the initial connection being establised but then stalling, see attached image.
  • Retired_Member's avatar
    Retired_Member
    I'm seeing the same issue since I upgrade firmware on my Orbi to version 2.5.0.38. I finally disabled Circle and noticed my issues were resolved. Seeing failure to load some sites across various apps and websites.
    Hoping this will be resolved so I can go back to using Circle in the household.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Retired_Member, this is currently being worked on by engineering. We will provide an update once available.
      Dexter
        stevenhar
        Star
        After many debugging sessions with L2 support and waiting for engineering to respond for weeks I just recieved a reply that they can't find the issue so recommended getting a refund for our circle subscription.
        I must say this is a very disappointing response and not something I would have expected.
        Just to be clear this means anyone trying to access support sites being run by zendesk, including circles own support site, with circle enabled are unlikely to be able to do so.
