- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Sites inaccessible because of Circle since last firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since firmware 2.1.4.10 some sites are inaccessible (eg blogspot.com, icloud.com) with Circle enabled, even with no filter level.
By disabling Circle, everything works perfectly.
Obviously, with the previous firmware there was no problem.
I temporarily disabled Circle hoping that an update will fix the problem.
Some observed the same behavior?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Sites inaccessible because of Circle since last firmware
Have you removed Circle from the system, then re-installed it and set it up from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have experienced the same exact problem.
I have reset circle and set it back up as a new circle account and the same problem exists.
Clearly a firmware problem, because until 2.1.4.10, circle ran great, now it it having problems.
Until netgear fixes these problems, future mesh router consumers should absolutely look elseware. Too many hours of headaches, with no response from netgear.
Shameful
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tested this with my system and I am not seeing the same issue can you give me some more examples of websites that do not work with circle enabled.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do a filtered search
ebaumsworld.com
Google speed test (2 separate words) then click the blue box to run speed test. Do not click link to Speedtest.net
- Mark as New
- Bookmark
- Subscribe
- Permalink
On my side with any filter level activated : ***.blogspot.com, icloud smtp server, some games like Score Match on iOS...
Cicle disable, everything is ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I still am not seeing the issue I have applied all the default filters maybe try to change your DNS in your orbi Internet settings to googles DNS and then try with circle enabled.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Darren,
the change that that I am going to make is the following:
return Orbi system and outdoor Orbi to Costco
i have already ordered an Eero mesh WiFi system and ordered Disney circle
I have chosen to no longer participate as an UNVOLUNTARY beta tester for Netgear with these forced firmware updates.
Best of luck to everyone, but the fact that Netgear is still pushing the firmware to users after all these problems, shows they really don’t care about the end user experience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Exact same problem with Circle after the 2.1.4.10 firmware. Some websites (not all) get stuck on "resolving host" before eventually loading a page with only text (as if the css isn't loading). For me, it did this with speedtest.net and I'm endlessly "connecting" to channels within a Discord server. Setting a device to "unmanaged" or disabling Circle all together immediately resolves the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, same here. I responded earlier with some details but my response has been removed from this thread (is Big Brother watching?)
With Circle enabled, numerous sites will not load and say "resolving host". Disable Circle and all is fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So i'm not alone.
Another website blocked by Circle : orbilogin.com !!
- Mark as New
- Bookmark
- Subscribe
- Permalink
ah yes, the irony of "orbilogin.com" not resolving......
If you have not tried this already, then try accessing the router using the IP address. On your local network it should be: http://192.168.1.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you delete your post? Or did netgear delete it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did not delete it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here. Took me way too long to troubleshoot. I have tried numerous things. I have done a factory reset on both router and satellite, even tried going back to an older version of firmware. I have tired comcast dns, google dns, open dns, then new dns from cloudfare all behave the same. Factory reset was a pain because not only did I have to reset Orbi WIFI, I had to also reset my entire Circle setup in app. I lost all the Circle profiles and custom filters, rules I had setup for our kids. This issue impacts several sites I use on a daily base, and my kids have let me know that it also impacts voice chat sites (such as Discord) that they use with their friends when playing online games. So at this point I have reset, restarted, re-installed everything I can and "no joy". Numerous sites will not load and say "resolving host". As soon as I disable Circle, the sites resolve and resolve very quickly.
Oh yea, in another bit of irony: often the "Orbilogin.com" will not resolve with Circle enabled, so I have had to use the Orbi IP address to access the admin to disable Circle.
I have recommended (and they have purchased) Orbi systems to numereous friends and family. I even drove with my Uncle to Best Buy to buy Orbi and then installed it for him. He called me recently, and I was his "tech support" for an hour on the phone becuase he was having an issue after a forced firmware update.
I have been very pleased with Orbi..... up until recent firmware updates and then this issue with Circle.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have escalated this issue to engineering and will let you know what I find out about this issue.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
that is my post
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanxs DarrenM !
I disabled Circle... for the moment
- Mark as New
- Bookmark
- Subscribe
- Permalink
Our engineers are looking into this if someone could help that is having this issue please send me a PM with your Orbi serial number, when you first started seeing this issue and your debug log where you can get to by going to https://192.168.1.1/debug.htm start a capture then enable circle try to visit a blocked site and then stop the capture and send me that file.
Thanks
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, after re-enabling circle, it appears to be working now.
Spoke too soon, it eventually started doing the same thing again. Will send logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Our partner, Circle, confirmed that their service suffered some downtime affecting some of our customers. The issue is resolved now and Circle should function as intended. We are sorry for the inconvenience this may have caused. Please let us know if you still see any issues
Let me know if the issue still presists and we can look into it futher.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just re-enabled circle and could not even go to speedtest.net.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still seeing the same problem with "Resolving Host" on R7000 with Circle enabled. Once disabled, everything works great.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Runs great. The family has stopped chirping at me about the network.
Off to Costco today with the Orbi return.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Exactly the same problem occurs right now...
