drdoz's avatar
drdoz
Apprentice
Jul 21, 2018
Orbi/Circle and Apple TV
When I have Circle enabled, my Apple TV becomes unusable. Almost none of the apps work (netflix, bbc, even the app store). I have the device marked as "unmanaged," and yet Circle is still apparently screwing with its connections.
I also use Layer3 cable-over-internet TV and this also seems to have problems with Circle. Why isn't "unmanaged" really "unmanaged?"
  • drdoz's avatar
    drdoz
    Jul 22, 2018
    Thanks for the reply. Both issues are resolved. After several restarts of both devices, Circle finally stopped managing the Apple TV. I found that the layer3 device actually had 2 connections (one cryptically named) and I needed to unmanage both.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi drdoz,
    Welcome to the community!
    1. Are the same services (Netflix, BBC, App Store) functioning on another unmanaged device?
    2. Have you tried setting a filter level (Adult) for the Apple TV and check if the issue will persist?
    Dexter
    Community Team
    • drdoz's avatar
      drdoz
      Apprentice
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi drdoz,
      Thank you for the update and confirmation. Glad to know you got it working.
      Dexter
      Community Team
